PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Ps4 dualshock controller won't turn on
Hello everyone.
I have 2 ps4 controllers.
One of them doesn't go on. If I put them on the charge cable on the ps4 they lit orange as usual but as soon as I put them off the cable it goes out. If I press the home button it won't turn on. Only via cable.
So I thought that it was the fault of the battery. I bought a new battery out it in and still the same. The other controller functions without problem and this one also but doesn't go on wireless.
Please help what can I do?
Score 14
11 Comments
So it goes on, and you can use it, while its wired?
by
Yeah like me
by
I can’t log on my PS4 my controller won’t connect when it says hit ps button to start any help
by
I'm having the same problem. My PS4 controller won't turn on without connecting a USB cable, then turns yellow and once I click the ps button I can use it. Once unplugged, it turns off and can't use it wireless. Battery not charging, hit the ps button, nothing. Changed USB cables, nothing. I don't want to buy a replacement battery if it's another problem.
by
My PS4 has a message Cannot start the PS4, connect the Duelshock 4 using the USB cable and then press the PS button. However when we tried that with a few cables the controller glows yellow once then goes off and the PS button does nothing. WE have tried using the PS button and Share button together while connected with the USB cable to reconnect it but nothing. Any advice?, is it the controller or the PS4?
by
Show 6 more comments
Add a comment
Chosen Solution
It's amazing how this happens in realtime
but never noticed till it quits with triggers
dropping out etc.
Took me about 3 days & several tear downs
under bright light to see slightest evidence
of micro spill, possible sip of coffee combo
sneeze. And you have enough force to get passed
Joy sticks.
Sure enough, a stain mark about size of pencil
eraser bridged across a processor from the board surface.
Only tool used,
Trimmed tooth brush,, with scissor,
making it uniform, dipped in five drops of rubbing alcohol
Now forced wiped at full flex of bristles
across paper towel to clean the brush, and
leave brush wetted just right,,
with battery removed, going at the board in scrubbing action,
quickly drying it with paper towel,, vs micro cloth - that tends
to grab at everything..
Give both sides of board a scrub,
tapped dry, give it a shot of warm air.
Hair dryer what ever,
Set it aside w/o battery for an hour.
Put battery on w/o bottom cover,,
does it work now ?
Note: make sure bump strip to circuit board
contacts are bright - this strip controls all Buttons/Triggers
Best of Luck.
Note2:
I meant to add a custom shield to lay over circuit board,
by simply cutting sample from ziplock bag,, pull up joysticks
and give it one more edge of protection.
But I was so thrilled to actually get back to killing Assassins
I totally forgot.
Score 4
5 Comments:
I will give it a try some day. I won't be active on the ps4 anymore because of school hahaha. Summer is gone
by
Well For Sure you have Priorities Lined Up for Perfection,
Excuse Granted Sir @!
by
Hello to and congrats to those who took the effort to go in deep to get there controller
to work again.
3 yrs later now and the controller still works great.
Although if running across the village in ACR using R2 trigger, while jogging speed, it's noticed if I make effort to squeeze it a tad more, now I run machII.
But squeezing trigger more in other apps seems to make no difference running.
Not sure what to think, and hate the thought of taking him apart, when a second New controller should be handy first.
Truly surprised battery has lasted this long, when sitting in storage under extreme conditions.
Possibly freezer zip lock bag was the trick keeping it protected from moisture and dust.
Cheers
by
My controller started shaking after trying this. Did that happen to anyone else?
by
A little late getting back here, but hopefully you found a cure fir controller not turning PS4 on.
Just the other day, a friend stopped by with exact issue, so I'll shout out to him to bring controller by, and I'll take a look inside and see if it's possible to fix by cleaning him.
Best of luck..
by
Add a comment
Most Helpful Answer
I had this issue too. Won't turn on with ps button, put charge cable in and it'll blink orange then turn off, but still wouldn't turn on. Reset button didn't help either.
I ended up pulling it apart, cleaning the ps button and the circuit it sits on. Worked after that. (My kids use that controller) So if all else fails, a good service and clean can do the trick especially if something may have been spilt on it.....
Score 5
2 Comments:
I tried doing the same exact thing as you did, but my screws wont come off. Is there another way to fix it?
by
I had the same issue. Since cleaning the conductive film of the home button didn't work, I bought a new one. It worked perfectly afterwards.
by
Add a comment
Here’s a solution. It may work for you.
https://youtu.be/GBpqfhPPJPw
Score 2
2 Comments:
Hello Alex, thank you for your video. My controller was completely dead, i went step by step using your video. I got the blue light to turn on through Ds4 windows. The only difference was that my PS button brought up a window on the laptop when i pressed it compared to yours that did not. Could the issue be the same as yours? Thanks.
by
Gregory were you able to solve the problem i have your exact problem. PS button works and controller works with usb cable. On battery it doesnt turn on. Battery is charged and tried to reset the controller as well but no joy :(
by
Add a comment
Having same problem, I opened the controller and cleaned it still it's refusing to come on…this happened after I stopped using it for a while (2 months)
1 Comment:
I had the same problem but was fixed buy holding the reset button for 5 seconds. On the controller
by
Add a comment
My did the same just switched off but when you connect the charger it lits up orange but doesn't switch on either
1 Comment:
When you try to turn the PlayStation controller on while the charger is in but you cannot so you got to remove it to turn it on double shock cheap China b*******
by
Add a comment
Hi everyone!
So one of my older controllers had a bit of the usual trigger problems and what not but worked fine, one day gave it to me younger brother to play on the ps4, so he probably used it a but roughly by maybe hardly pressing the buttons and what not. Yet, suddenly he came to me and said its not working and it isnt, its not turning on and not charging. When the PS4 is on and and I plug it in the orange LED lights up and fades and never comes back up.
So please help would be nice. I did reset it yet no avail.
1 Comment:
When LED fades then off,
Means Battery Is Fully Charged.
Probably restart PS4- and reconnect Bluetooth Controller, using cable.
PS4 should see controller, or controller was damaged with liquid.
Cheers
by
Add a comment
Guess I missed some of the posts after a major move and no internet access -
Hopefully they got their controllers back up in the end.
I suspect when controller was taken apart, the ribbon cable with exposed contacts is not pressing against mating contacts with enough pressure. I did make a cushion to assist this contact pressure a little more, and it's working great.
Fortunately my controller is still going strong, but I did modify trigger silicone pads that end up a little damaged and don't output 100% when tested on laptop and the app that shows triggers in real time.
The mod worked quite well where I should have just ordered new silicone pads, but just couldn't wait to get back to Racing on GTSport.
If someone would like to see detail on trigger mod, I do have images on file. The key is the trigger where the bar that makes contact to silicone pad has sunken into and has worn down into pad
where a sleeve was made to slip over trigger bar to make slightly bigger footprint on silicone pad.
Sleeve was cut from plastic QTip, and cuts made in sleeve to slip over the bar. Nothing more was needed, assemble and ready to go.
The hard part, getting sleeve that's very small to handle, then inserted in place. Pretty sure tweezers were needed.
Cheers
Add a comment
Having same issue my controller charges but PS won't connect when charging and it won't turn on when I push PS button.only way I get it to connect is by using my older controller to Bluetooth it after forgetting the controller but after 10 minutes the new controller just turns off and I have to do it again for it to work it's really annoying
Add a comment
Add your answer
Ibosaid will be eternally grateful.
Past 24 Hours: 42
Past 7 Days: 312
Past 30 Days: 1,481
All Time: 221,437
